May 14, 201610 yr IT LIVES. l would like to weave tales of suuuuuuper Genius, but i cleaned the tank, petcock and carb and it fired right up. lm amazed at how smooth it is, zero and i mean zero vibration. lve ridden it about 5 miles, its quite peppy with forth gear being quite 'tall'. The clutch is slipping, stuck plates most likely, ive just raided evilbay, and got a baffle, brake lever, manual and gearshift lever coming, didnt realize it was a heel and toe shift until i had to change down, well thats what hands are for. The wiring will need some TLC, but nothing that cannot be sorted. Not done properly yet, will come up cleaner when im done.
