Posted May 11, 20169 yr I have a yamaha LS2-100 that will not run. I have been riding it for about 6 months with a new top end. It ran perfectly until it bogged out during a ride. I just figured it was a carb issue, but that's not the case. I cleaned the carbs twice and cleaned the gas tank. Also put brand new plugs in it. I finally got it to idle fine, but as soon as I take it off the stand and put it in gear it instantly dies. I can't seem to figure it out. Any help would be greatly appreciated. Thank you.
May 11, 20169 yr yeap, sound like a switch or wire fault. remove the switch and see what happening if you connect the wires directly
May 11, 20169 yr Moderator C'mon guys, side stand switch in 1972!! You say 'bogged', (in your non introduction first post, that isn't in the new members area, HINT!). Do you want to expand on that a little, were you at high rpm on a dual carriageway. Low on fuel, low on oil, hot day, long trip, bike cold, did it start easy afterwards, do you live in the mountains or the desert, ( that kind of information could be in an introduction ).
May 11, 20169 yr Moderator are the clutch plates stuck together, is it simply stalling because the clutch wont disengage? can you push the bike when it's in gear and the clutch is disengaged,? ... if you cant the plates are stuck together there, lots of help and and no intro you're doing well
May 12, 20169 yr C'mon guys, side stand switch in 1972!! I admit, I failed to look up what an LS2-100 is/was made
