Dt175mx biggest front sprocket
Simon46
As im peed off going thru all the gears in 5 secs what will fit?
Link to comment
Share on other sites
What have you got at the moment, 16/45 is normal and should give around 60 ish as a top whack. Pulling more will hurt acceleration.
Not sure there is room for a 17.
Link to comment
Like we've said before, little engines can only breath so hard. 16 is fairly normal but you might not be able to get a 17 to fit, perhaps look at dropping a tooth or two on the back? But like has been said, with such little power you can't expect the earth, you can go up a front tooth or down a back tooth but if you don't have the spare HP to propel you at that speed then that's that. But from a 175cc 2 smoke I would have expected more then 60mph.
http://www.motorcycleproducts.co.uk/sprocket-yamaha-dt175-1974-1975-1976-1977-rear-standard-p-157812.html?gclid=CNLpwIzb7MsCFYIW0wodOJ4M7g
That's a 37 rear for a DT175, you can give it a go but taking out some gear will probably do little more than hurt acceleration. Only so much can be done with a little engine.
Link to comment
Yambits DID 15/49 combo. Not looking for top speed just staying longer in the gears. Wemoto show a plus 2 sprocket might just try a 16 first.
Link to comment
Hi,
I went one tooth up from standard on my 1g1 dt 175 front sprocket, however I had fitted a TY trials gear shift out put cover using the supplied allen socket head screws, the screw sockets are taller than the original cross head and one of them would rub on the chain, I had to reuse one of the originals,
I am at work and I cannot remember the amount of teeth, but can check later today if you want.
  • Like 1
Link to comment
The rimstops turn it into a counterweight!
Link to comment
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Recently Browsing
