pete k Posted May 12, 2006 Posted May 12, 2006 I have a FZR400 1WG,which is running fine till I reach top gear, then after a few minites in top gear it starts pulling back as if it is running out of fuel - but it is not. I have put a new rectifier on but sometimes the idling still sticks at 2500 revs and then will slowly reduce back to tick over. I have also replaced the main jet "O" rings - but still have this problem in 6th gear - can any one please help. The bike is on a D plate but the engine is not original - it is newer.
jimjam Posted May 13, 2006 Posted May 13, 2006 You need to really thoroughly check the rubber conectors from the carb to the engine, you may have a very faint air leak.
GED Posted June 1, 2006 Posted June 1, 2006 I have a FZR400 1WG,which is running fine till I reach top gear, then after a few minites in top gear it starts pulling back as if it is running out of fuel - but it is not. I have put a new rectifier on but sometimes the idling still sticks at 2500 revs and then will slowly reduce back to tick over. I have also replaced the main jet "O" rings - but still have this problem in 6th gear - can any one please help. The bike is on a D plate but the engine is not original - it is newer. hi the fact that its sticking at 2500rpm then settling down is a sure indication of it running lean,check the float heights,mixtures screws,main jet size,air leaks around intake rubbers,is the bike standard????.also check the fuel tank breather
