Intermittent indicator 2010 XJ6
Hi,
About once per week the indicator stops working on my 2016 XJ6 Diversion. The hazrd warning also stops working. All other electrical items such as headlights, and brake lights seem to work fine while the indicator stops working. I noticed tonight when I stopped and turned off the bike then turned back on the ignition but did not start the bike, the neutral bulb on the instrument panel was weak (*) but the indicator and hazards worked ok. After switching on and off a few times without turning over, the neutral bulb seemed strong and the indicator continued to work fine.
Has anyone else experienced this infrequent indicator/hazard "failure" on the XJ6? Does anyone have any suggestions on how to diagnose this problem?
Thanks,
Clive
Edited by cliverlong
(*) The neutral bulb issue may be a red herring as that symptom has "gone away"
Easy. On a 2016 bike. Its the dealers problem.
Confused
Is it 2010 or 2016? Differnce in your info
As above if its 2016
If its 2010, sounds like poor connections somewhere. Check em all, make sure there clean and dry
