Posted March 2, 20169 yr evening all, just after a little info on the footpegs on a dt125r, i know it may seem a bit anal and over the top but i have found some footpeg rubbers(not the pillion ones) for sale on a website but they are quite expensive so was wondering if all dt125 front footpegs are the same size as the advert states they will fit a DT125re and Dt125dx 04-07 ?, for the record my dt is a 52 plate 125r and the footpeg measures 80mm long and 30mm wide and has a 6mm fixing hole to secure the rubber, thanks
March 4, 20169 yr Too modern for me, but try in here, as thers lots of DT owners, . http://yamahadtclub.proboards.com/
March 6, 20169 yr Aren't the pegs on your bike made of steel and have spikes on the top, so what rubbers?
March 12, 20169 yr Author the footpeg rubbers slip over the top of the footpegs and are held in place with a 6mm bolt/screw inserted through the fixing plate that is fixed in the centre of the footpeg
