Hey all hope all is well no Xmas madness is over I've pulled my project 1990 3rs yz125 out to finish her off. The last owner welded the inner hub were the springs tighten to so undoing them caused it to snap. The problem I'm having now is no one seems to be able to get one not know what other years may fit lol so I'm calling on the yamaha friends for some wisdom in helping me find one or info on other years please!!!!! Thanks in advance always appreciate it
no-one knows what you are talking about.
inner hub, is that a wheel hub?
what spring?
what tightens and snaps?
The inner hub on the CLUTCH. There's the basket then the inner hub with the splines on then friction plates,pressure plate then springs Whitch go throught the pressure plate in to the inner hub and tighten down
The 5 lugs where the springs tighten into on the pic two if mine had been welded and snapped
Part no:3JD-16371-00 I think, start from there.
Here's a parts diagram
Number 4 is the part I need to source but I carnt find one for 89/90 yz125 this is my question does any one know if any other years will fit
https://www.fowlersparts.co.uk/parts/4076662/yz125-3sr1-1990-999-a/clutch
Best you can do is check the part no against other years on that website
the good thing about Yam is they cross used parts over the range.
look at Yam bikes of the same era
