February 10, 201610 yr Hey all hope all is well no Xmas madness is over I've pulled my project 1990 3rs yz125 out to finish her off. The last owner welded the inner hub were the springs tighten to so undoing them caused it to snap. The problem I'm having now is no one seems to be able to get one not know what other years may fit lol so I'm calling on the yamaha friends for some wisdom in helping me find one or info on other years please!!!!! Thanks in advance always appreciate it
February 12, 201610 yr Moderator no-one knows what you are talking about. inner hub, is that a wheel hub? what spring? what tightens and snaps?
February 13, 201610 yr Author The inner hub on the CLUTCH. There's the basket then the inner hub with the splines on then friction plates,pressure plate then springs Whitch go throught the pressure plate in to the inner hub and tighten down Just now, dsb2014 said: The inner hub on the CLUTCH. There's the basket then the inner hub with the splines on then friction plates,pressure plate then springs Whitch go throught the pressure plate in to the inner hub and tighten down The 5 lugs where the springs tighten into on the pic two if mine had been welded and snapped
February 13, 201610 yr Part no:3JD-16371-00 I think, start from there. Here's a parts diagram Sent from my E6553 using Tapatalk
February 13, 201610 yr Author 1 hour ago, finnerz89 said: Part no:3JD-16371-00 I think, start from there. Here's a parts diagram Sent from my E6553 using Tapatalk Number 4 is the part I need to source but I carnt find one for 89/90 yz125 this is my question does any one know if any other years will fit
February 13, 201610 yr https://www.fowlersparts.co.uk/parts/4076662/yz125-3sr1-1990-999-a/clutch Best you can do is check the part no against other years on that website Sent from my E6553 using Tapatalk
February 13, 201610 yr Moderator the good thing about Yam is they cross used parts over the range. look at Yam bikes of the same era
February 13, 201610 yr Dab in ,its the last one http://www.cmsnl.com/yamaha-yz125w-1989_model9553/bossclutch_3jd1637100/#.Vr9dk7SLTMo
February 13, 201610 yr Get stuck into these, plenty on e bay usa, just double check for compatability http://www.ebay.co.uk/itm/YAMAHA-CLUTCH-HUB-93-11-YZ125-YZ-125-CENTER-BOSS-/231762737655?hash=item35f622b9f7:g:7osAAOxyUrZS0YP2
