sorry for having a million questions and bustin everyones ass, but i have another
.when I put my bike into 1st it starts moving forward, even with my clutch fully held in I'm having to hold the brakes to stop going, n its murder getting it back into neutral. Is this something I can fix myself? Or would I be best taking it back to a mechanic?
Sounds like you need to adjust the clutch cable
Oil on what? Or do you mean in the engine?
Might cause an issue, but I would definitely look at cable adjustment first
Try draining some oil out,I had the same prob,I syphoned oil from filler drip drip it took hours to get 1litre out.but I was using fish air tube.s b
Get the excess oil out first
Bike has to be vertical upright to check the level in the sight glass
Send me a PM and ill reply with the setting procedure for the clutch from the XVS125 manual
2 weeks and 3 mechanics later my bike is running fine. Thank fu(£. Thanks everyone for their help. I think no matter the problem now ill be able to fix it cause ive had this bike in a million pieces.
