This post is 3216 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi everyone I have just bought a1980 dt175 wiring loom for my 1982 dt175 on the 1980 loom all I can see is different is the extra wire out of the magneto and the Cdi unit which is the red wire if I just discard the extra wire will that be ok and if anyone knows anything different would be grateful on their input
Why discard? You mean disregard and just leave it unconnected.
Otherwise yep same ol yamaha. Aint broke etc,etc.
Yes mate just leave out red wire, is that the only difference between the 2 looms, by the way thanks for answering cynic
Yep, only difference. You might find some tiny variation, the voltage regulator moved (79 to 80 not far though) otherwise yep, same. BTW its not a 1980 loom if its 7 wire, it will be a 78/9 loom.
  • 1 month later...
Possibly. Some 125 were cdi. Some had points. Without you having done an introduction (HINT) in the new members area. Were guessing.
Prob find it will come ready for the 7wire cdi and just use what you need.
