DT125 Main jet, reeds, dt230 snorkel?
At the moment my bike has a full dep system and has been derestricted (speedo method). I'm going to buy some boyesen dual stage reeds and replace the standard air box snorkel to the one that came with the dt230, as it is slightly larger. My question is, for the upgrades I have just listed, what size jet do you think would be appropriate to upjet to? I have seen posts of people running similar upgrades running a 230 main jet and some running a 250 main jet. My powervalve is not pinned open. Also, is there any other mods that are worth doing while I do these things, I have seen some things about people modifying the rubber bit on the intake manifold. Cheers
So the upgrades are:
Full DEP system
Derestricted (speedo)
Boyesen dual stage reeds
dt230 airbox snorkel
Anybody???
Its suck it and see  with 2T"s.  your ports havna been opened , this gives the biggest performance boost, , short run ,and plug chop .
will tell the story ,    RACE 2 strokes try to get as lean as possible.  but thers risks  in this,  .
1 hour ago, Airhead said:
wont be far wrong with a 240 I would think
I'll get a 240 and a 250 as they're only 5 quid each...
  • 4 weeks later...
Hi
how did you get on with your mods?
the rubber bit in the manifold you mentioned helps the airflow and from what I have read has a detrimental effect if removed.
nige
I've got the jets and the reeds are one their way but I'm thinking about skipping the dt230 snorkel and just remove the stock one instead. I've heard some bad things about doing this though so I'm not sure atm. I'll start a new thread and see what people think.
