leightonbike121 Posted December 13, 2015 Posted December 13, 2015 hi,high & low beam isnt working on my 09 xt125x,everything else seems ok,including the side light & tail light.i suspect that it may be down to a 5 pin relay located behind the right hand sidepanel,next to the cdi.does anyone know if it could be this relay at fault? (and would it only affect hi/lo beam.) thanks in advance for any advice that is offered.
leightonbike121 Posted December 13, 2015 Author Posted December 13, 2015 yes,tested the bulb & its fine.
Moderator Cynic Posted December 13, 2015 Moderator Posted December 13, 2015 Heard that all too often. Squirt some contact cleaner in all the switches and check your fuses. Doubt its the relay. Could be but in my exp when a relay fails it just stays in one state, ie main or dip beam. Checked the headlight earth?
leightonbike121 Posted December 13, 2015 Author Posted December 13, 2015 hmm,will re-check the connections but im fairly confident that they are all good,the switchgear is spotless & had a squirt of wd40.it only has one fuse,(i believe) & thats located on the starter solenoid & if that blows nothing will work so i thought id narrowed it down to a relay,or,as you suggested,the earth....which seems more likely,the more i think about it.i think i got to nip out into my workshop & check that right now as the curiosity is getting to me, lol.
leightonbike121 Posted December 18, 2015 Author Posted December 18, 2015 ok,its not the earth or any of the connections.have bought a relay of ebay,only £8 so hopefully that will cure it.
Wirie01 Posted March 10, 2020 Posted March 10, 2020 Hi i know that this is an old Post but you never know who will respond right. I have a 2005 xt125x and am looking for parts. Does not matter what parts you have.
