December 13, 201510 yr hi,high & low beam isnt working on my 09 xt125x,everything else seems ok,including the side light & tail light.i suspect that it may be down to a 5 pin relay located behind the right hand sidepanel,next to the cdi.does anyone know if it could be this relay at fault? (and would it only affect hi/lo beam.) thanks in advance for any advice that is offered.
December 13, 201510 yr Moderator Heard that all too often. Squirt some contact cleaner in all the switches and check your fuses. Doubt its the relay. Could be but in my exp when a relay fails it just stays in one state, ie main or dip beam. Checked the headlight earth?
December 13, 201510 yr Author hmm,will re-check the connections but im fairly confident that they are all good,the switchgear is spotless & had a squirt of wd40.it only has one fuse,(i believe) & thats located on the starter solenoid & if that blows nothing will work so i thought id narrowed it down to a relay,or,as you suggested,the earth....which seems more likely,the more i think about it.i think i got to nip out into my workshop & check that right now as the curiosity is getting to me, lol.
December 18, 20159 yr Author ok,its not the earth or any of the connections.have bought a relay of ebay,only £8 so hopefully that will cure it.
March 10, 20205 yr Hi i know that this is an old Post but you never know who will respond right. I have a 2005 xt125x and am looking for parts. Does not matter what parts you have.
