hi,high & low beam isnt working on my 09 xt125x,everything else seems ok,including the side light & tail light.i suspect that it may be down to a 5 pin relay located behind the right hand sidepanel,next to the cdi.does anyone know if it could be this relay at fault? (and would it only affect hi/lo beam.) thanks in advance for any advice that is offered.
K.I.S.S. have you checked the bulb? ;)
Heard that all too often.
Squirt some contact cleaner in all the switches and check your fuses.
Doubt its the relay. Could be but in my exp when a relay fails it just stays in one state, ie main or dip beam.
Checked the headlight earth?
hmm,will re-check the connections but im fairly confident that they are all good,the switchgear is spotless & had a squirt of wd40.it only has one fuse,(i believe) & thats located on the starter solenoid & if that blows nothing will work so i thought id narrowed it down to a relay,or,as you suggested,the earth....which seems more likely,the more i think about it.i think i got to nip out into my workshop & check that right now as the curiosity is getting to me, lol.
ok,its not the earth or any of the connections.have bought a relay of ebay,only £8 so hopefully that will cure it.
  • 4 years later...
That post Dan... was back in December 2015 !!!
  • 1 month later...
Hi i know that this is an old Post but you never know who will respond right. I have a 2005 xt125x and am looking for parts. Does not matter what parts you have.
