December 7, 201510 yr I am sure this has come up many times before but the search on this site doesn't work. I want to replace my fuel tap with a simple on /off / reserve type instead of the vacuum type I have. The bike has trouble starting unless I use the prime mode on the tap for around 3 - 5 seconds. It will then fire and usually start. Once running every time you approach a junction you have the keep revving it or it just dies (lack of fuel). It will then not start unless I prime it again. I am sure many people have come across this but has anyone solved it ? would really appreciate some feedback thanks.
December 7, 201510 yr Have you checked the fuel cap vents on top of the tank? if they get blocked you have a vacuum in the tank, mine (XJ750) never gave me a moments bother and they are pretty robust, a tap kit only costs a few quid. I like the fact you can't turn it off and it's always ready to go. Have you checked the rubber tubes as well? they perish and let air in and then your fuel flow just stops.
December 7, 201510 yr Author Thanks for the reply I did overhaul the tap a year ago when I was trying to sort out the original starting issues. I will check again though as I am learning not to ignore the obvious. To date I have spent ages on the carbs and replaced points condensers plugs battery etc. bike has a 400 barrels and head.
December 7, 201510 yr Moderator I think a DT400 tap will fit, I have one on the FZ600 and yam tend to have the same type of tank connections
