November 28, 201510 yr Hi allThe DT125X 2005 i have has hazard warning lights, I have a slight problem when switched on they flash once then nothing the indicator light on the dash stays on.My indicators when switched on left and right work fine.I can only find one indicator relay on the drawings.Does anyone have any ideas ??Also as they are fitted are they part of the M.O.T ??Any advice would be very welcome.cheersnige
November 28, 201510 yr Are your indicators/bulbs standard? I had a similar problem when I upgraded my indicators, and the new ones exceeded the wattage of the stock relay.
November 28, 201510 yr Author Are your indicators/bulbs standard? I had a similar problem when I upgraded my indicators, and the new ones exceeded the wattage of the stock relay.I think they are standard, i think ba9 type not LED or the likesthanks by the way Edited November 28, 201510 yr by nigel smith forgot thanks
November 28, 201510 yr Yes but you need to check the wattage of all the bulbs, and compare it to that of the relay.
November 28, 201510 yr Hi allThe DT125X 2005 i have has hazard warning lights, I have a slight problem when switched on they flash once then nothing the indicator light on the dash stays on.My indicators when switched on left and right work fine.I can only find one indicator relay on the drawings.Does anyone have any ideas ??Also as they are fitted are they part of the M.O.T ??Any advice would be very welcome.cheersnigeI can assure you Nige they are not part of the MOT, only indicators are but not hazards.
November 28, 201510 yr Moderator The indicators work as they shouldThe relay works tooI'd try cleaning the switch contacts, it's the only thing unique to hazard warning lights, maybe even a spray of WD40 will do it? Edited November 28, 201510 yr by Airhead
November 29, 201510 yr Author Thanks mike and paul for the advice,Well i have woken up today with full on MAN FLU so wont be going outside today, i feel like ( i think the medical term is) SHITE!!!!cheersnige
January 3, 20169 yr Author hi all i have had a look at my rear bulbs which are aftermarket and i cant see the wattage, presuming they are over ten watts and the relay cant cope i have had a look on ebay for a different relay and found these. see link My standard relay is FE218BH rated a 10w x 4 for the hazard lights 10w x 2 for indicators Could i use the FE246BH rated at 21w x 4 for hazard lights 21w, 23w and 27w x 2 for indicators http://www.ebay.co.uk/itm/281833651894?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT what i want to know is for £6 second hand will this solve my problem or cause other problems with indicator speed ect thanks in advance nige
January 3, 20169 yr That should be fine. Funnily enough it's only the wattage that affects the speed lol
January 3, 20169 yr Author 1 hour ago, finnerz89 said: That should be fine. Funnily enough it's only the wattage that affects the speed lol cheers pal i will blow my Christmas bonus on one then
January 4, 20169 yr Moderator 22 hours ago, finnerz89 said: That should be fine. Funnily enough it's only the wattage that affects the speed lol Huh. Power is a product of resistance, current and voltage. So all 3 affect the speed....
January 4, 20169 yr True. But a change in wattage affects the current and resistance therefore the speed. I probably didn't word that brilliantly but hey ho
March 14, 20169 yr Author On 3 January 2016 at 7:16 PM, finnerz89 said: That should be fine. Funnily enough it's only the wattage that affects the speed lol Hi finnerz89 finally got round to trying the higher wattage relay and it works a treat so just wanted to say thanks for the advice cheers nige
