November 23, 201510 yr Hi wold like some helpcan I put yz forks on my 2002 dt 125?? And if not what other good forks can I use ?Thanks
November 25, 201510 yr If they are the same length, diameter, and the wheel bearing and brake assembly fits I can't see why not. What is the purpose of changing the forks for a different model?
December 29, 201510 yr I know it's an old thread but yes you can fit the yz forks with out much hassle but will need the front wheel, yokes, and brake setup also will need to look into a universal speedo as brackets will need to be modified to hold the speedo and ignition also the yz wheel has no speedo drive but this could also be over come by finding a wrf front wheel with a speedo drive
