Hi there... I really need your help guys.. I bought piston ring sit  for my Yamaha DT175.. The other ring has an " N " mark in it.. So where would I put this Top or Bottom groove of the piston?
What make of rings ,?
Si airhead... what do you mean when u say "keystone" ??
the keystone ring will be thinner at the inside diameter and thicker at the outside diameter and so the top ring groove will taper to accommodate that
If you put the bottom ring in the top groove it will not seat fully, it will stick out a little from the side of the piston
see here, and note from the link that 'N' faces up when fitted
http://www.golfcarnews.com/technically-speaking-mayjune-2008/
Edited by Airhead
Thanks alot sir airhead, a big help for.me...btw airhead.. is 34mm flat slide carb is good for my DT175??
I would stick with the standard one, they aren't the most modern of engines so a big fancy carb would be wasted on them I would think
Thans alot again sir... a big help for a noob like.me... cheers
