Yamaha XT125 R 2010 Noisy Gear box?
Matt D
This post is 3280 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Good morning all
I have just signed up as i have a issue with  my 2010 XT125 R and i was wondering if anyone has had a similar issue of know of a fix.  I recently bought my XT125 and it was running fine, but recently i have started to notice a kind of whine in 3rd and 4th coming from the left side of the engine which i assume is the gear box? Also i have started to notice that it is sounding noisy from the left side also when the bike is free rolling.  It kinda sounds like when a push bike is free rolling.  Has any one had this before? is it normal? is there a fix?
Cheers
Matt
Hi Matt, can I make a suggestion? It helps if you say Hello in the new members section BEFORE you ask a "how do I fix my bike" question' We get loads of one hit wonders on here who ask for help then vanish never to be seen again and they rarely if ever say "thank you" when advice is offered, makes folks wary of first time visitors, obvious really, it's not that we're unwelcoming it's more a "why bother if they won't even say hello", so if you would be so kind to pop over to the above section you might get more help. Just sayin.
No prob mate the more the merrier. always nice to have new folks join in.
How much oil in there, how old is the chain? Is it lubricated and adjusted properly?
A bad chain can do all sorts of silly tricks, that gearbox is the same as the dt and mine has survived 30 years of stupid so it would be what I checked last.
  • Like 3
The oil is topped right up and only 3 months old as changed it when i bought the bike. However i do think the chain could do with replacing as it is showing signs of wear and tear.  I will do so and let you guys know the out come.
Thanks for the advice
  • 4 weeks later...
Good News!!!
I fitted new front and rear sprockets and a new chain and it now runs a lot smoother and quieter.  Rear wheel must of been well out also.  All adjusted and aligned correctly and ride perfectly.
Thanks for the advice chaps
  • Like 3
