Posted October 25, 20159 yr Hi,  anyone know where I can get new swingarm bushes,spacers, endcaps & bolt for my dt125lc mk1  had to cut mine out with a grinder & only part salvageble is 1 nylon bush. Do the later dt,s share the same bushes?
October 25, 20159 yr Moderator get some bronze ones made, you have an original nylon so it should be easy enough to measure and look on ebay for similar ones
October 25, 20159 yr Author Yeah can do,   just wondering if other models shared the same bits and would be easier sourced as eBay has very little for the mk1  cheers
October 26, 20159 yr Moderator Try looking the other way. The 175mx gave its sw arm to the mk1 dtlc it may share the bushes.Â
October 27, 20159 yr Author Have found them on yambits, but its not clear which bushes are for my specific model, they all look the same. Might just email them as I need the bolt as well, which they don,t show as part of the kits they do.
