Steering lock key ! DT 175
Wessie34
This post is 3314 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Yeah fella, there's an 12 mm one on ebay so I'll measure mine later.
Got it running today but now it's blown the fuse ! So fault finding begins,  wonderful.
Edited by Wessie34
Link to comment
Share on other sites
Rectifier diode eh ? Not sure where it is but there's a silver case with fins on and one wire to it but it wasn't earthed when I bought the bike ( it was mounted onto a plastic bracket! ) so I mounted onto a good earthed bracket and assumed voltage rectifier ? Anyway, I guess it's a rect diode, I'll get the Haynes out this weekend and check it. If it's faulty does it just let the volts rise and therefore blow the fuse? I haven't checked running voltage yet as I thought it was a wiring issue. Thanks for the tip, Dave
Link to comment
There is a way of picking the lock, done this a few times on my XT frames, ones the lock is out there is a key number on the top flat section
that corresponds with the key number you need.
TTB
  • Like 1
Link to comment
Ah ! Wrong again, thought I knew what I was doing there for a minute. I'm hoping they're easily available.  Will check this aft.
Also,  thanks Tommy, I'll give it a go.
Ok, got a rectifier ordered, thanks
Edited by Wessie34
updated
Link to comment
  • Recently Browsing
