Dt175mx clutch shim size please ! Probably sorted now!
Me again ! Tightened the clutch centre nut and it locks to the outer ! Brilliant ! ( I've bought a pup springs to mind !) I've not sat down and worked out the mechanics of it as there is a shim behind the clutch outer and one between which the Haynes manual agrees with. But, they're both 3mm thick and wonder if the twat I bought it off swopped bits? ( it came with spare engines but clutches removed !)
so, any way off checking the correct thickness? I'll scan the web later but I thought I'd just throw it out there and hope, Dave
Edited by Wessie34
I was going to delete this post cos I think I now know ( but can't find delete button !)  anyway it appears to be 2mm according to Padgetts, if so that's the problem, I have one on order, although the price of if makes you wonder if it's being bought off Rossi's race team !!
Sorry,  couldn't load the pic, but it's no3 on the pdf, 90201-17543 !
