Hi, could someone please help, I have a 1991 fzr 600 genesis and I'm trying to balance the carbs, the problem I have is where do you connect the four hoses to on the carbs
taken the air box off and petrol tank but for the life of cant see anywhere to attach the hoses,
Regards Phil.
Ok look at the top of the carbs, between the carb and the throttle body you will see 4 rubber caps with metal clips, the same as hold on small water pipes, take off the metal clips pull off the rubber caps and that's where you put the balance pipes.
Have you found them? A reply always helps or a "thank you" even an INTRO in new members section goes a long way.
You will probably find them on the rubber intake manifold between the carbs and cylinder head with rubber caps on with clips holding them on as mentioned.
Hi sorry thanks for your help only just turned my computer on,but thanks for your help I will have another look.
Regards Phil
