My yamaha ybr 125 has developed a fault, as described posted in newbie section! Started to cut out while riding after a short stop, restarted while still moving. Now has begun to be hard to start. When starts runs sweet. 2006 standard carb version.
Sounds like a  dirty carb or a blocked fuel cap vent . Hard to say with so little info . I'd check those anyway . Could also be a blocked/dirty  fuel tank petcock .
Last time you changed the plug.
Well that made no difference! Fault same as before. Batt voltage ok, when it starts it runs ok for 2 minutes riding then cuts out. Reatarts and runs sweet! Then wont restart after turning off. Battery?
you really need to check if the spark has disappeared when it wont restart, perhaps the pulser coil is intermittently faulty? you'd need a workshop manual and a multimeter to check the resistance of this I 'd imagine
Brand new coil and lead fitted. plug cap in tolerance. Stripped and cleaned carb cehcked float and main jet set correct.
  On 15/10/2015 at 10:44, neversaydie said:
Is it a vacuum operated fuel tap
no. Fuel straight out of tank, through filter (checked) into carb.
As airhead said look here https://youtu.be/54mNJaAleCo
Sounds just like what your bikes doing.
New coil, stripped and cleaned carb, new plug. So clean fuel line clean electrics except for ECU. Cant test that!
Right. Cured i hope! Spayed electrical contact cleaner spray into ignition block. Now starts each time and no stalls yet! :D
