Ybr 125 cutting out and now hard to start.
David Wheatley
This post is 3324 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Last time you changed the plug.
As airhead said look here https://youtu.be/54mNJaAleCo
Sounds just like what your bikes doing.
Brand new coil and lead fitted. plug cap in tolerance. Stripped and cleaned carb cehcked float and main jet set correct.
no. Fuel straight out of tank, through filter (checked) into carb.
New coil, stripped and cleaned carb, new plug. So clean fuel line clean electrics except for ECU. Cant test that!
