Posted October 1, 201510 yr First post! Like the title says; just curious. Slowly putting an FZ600 together, got a spare engine from my Radian that needs a top-end rebuild (TL;DR: over-revved, my fault, lesson learned, moving on) and I was going to put that into it, but today I came across a 1985 FZ750 engine for only a little more than the cheapest price I've found for a top-end gasket set and four piston ring sets for the FZ/XJ/YX600 engine. This project is a bit-by-bit thing anyway, so the idea occurred to me that it might be fun to plug the 5-valve water-cooled 750 in there instead.I know the frames are similar; but does anyone happen to know if the engine mounts line up between the two models? If not, could I make it work with different mounting brackets at the front? Or would FZ750 lower frame rails match up to the FZ600 main frame? How about chain clearance?Thanks in advance - cheers! Edited October 1, 201510 yr by MrFlippant Random Letter Out Of Place
October 2, 201510 yr Moderator I doubt it, the FZ was an FZR400 bike originally so its already maxed out. go and say hello in the new members section first and intro yourself.
October 2, 201510 yr Moderator Normal practice for that kind of thing is to take the engine cradle from the 750 and graft that onto the 600. Lot of welding, very accurate expensive welding, jig work etc for lets be honest a worse bike.As said the 600 is a 400 frame with a big motor in it, they had to fit smaller carbs than ideal as it was.
October 3, 201510 yr it will fit but you may need to use a large hammer and a JCB digger.. not worth the hassle
November 17, 20159 yr It would fit, but it can be done. The question is how stable and balance would it be after the swap.
