Wrf426 2001-2 noise from clutch casing
Hitchen187
This post is 3276 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi guys i have a noise coming from the clutch casing side of my engine like a rattle noise but it stops when i put my hand on the clutch cover any ideas ill try to post a video on
http://youtu.be/9Zqnn1Hqvu4 this is the noise i have checked for movement in clutch basket its solid cam chain was changed about 3-4hours ago and i do oil n filter changes religiously every 3 rides any ideas peeps
If it sounds like this   https://youtu.be/DoBX5-QUdUU   then theres probably nothing wrong with it otherwise Kev might have the right idea.
Thanks for replys guys iv had it in to my mechanic today there was abit of freeplay in clutch basket he tried a different basket and it solved the issue ill post a link up now so you can see it if link doesnt work search wrf426 problem solved
http://youtu.be/jLR5XCpi2xc
Edited by Hitchen187
