Posted September 30, 20159 yr Hi guys i have a noise coming from the clutch casing side of my engine like a rattle noise but it stops when i put my hand on the clutch cover any ideas ill try to post a video on http://youtu.be/9Zqnn1Hqvu4 this is the noise i have checked for movement in clutch basket its solid cam chain was changed about 3-4hours ago and i do oil n filter changes religiously every 3 rides any ideas peeps
October 1, 20159 yr Does the noise stop when you pull in the clutch lever ? On a lot of bikes the clutch release bearing will rattle a little when not under any load . Not sure what the set up is on the WRf 426 though .
October 1, 20159 yr If it sounds like this https://youtu.be/DoBX5-QUdUU then theres probably nothing wrong with it otherwise Kev might have the right idea.
October 1, 20159 yr Author Thanks for replys guys iv had it in to my mechanic today there was abit of freeplay in clutch basket he tried a different basket and it solved the issue ill post a link up now so you can see it if link doesnt work search wrf426 problem solved http://youtu.be/jLR5XCpi2xc Edited October 1, 20159 yr by Hitchen187
