Front indicator not working
Hi can anyone tell me what is wrong with my indicator,
i have a xj6 the left indicators are working fine, but the front right is not working, the back right works but it is flashing at twice the speed it should be, I have changed the builb in the front but it is still not working
thank you
Hi, Ok it has to be a bad earth to the plug socket, try cleaning the bulb holder out with some switch cleaner and check the connectors from the loom to the indicator. It's usually a bad connector between loom and bulb. Do this right after you say "hello" in the New Members section !!!
