Most pertinently - is there one?
I can find Haynes manuals for all other years and capacities of DT but not the 1981 250MX. There are Clymer manuals from America. Any one had any experience with these? Would they differ that much from a Haynes manual apart from maybe using different measurements?
Cheers.
Measurements will still be in metric even tho USA uses AF I think, things like fuel tap will be petcock and some other odd ball names but easy enough to work out, Clymer and Haynes are near enough the same as to make no difference. Buy one and you should be ok.
Edited by slice
Wow! Quick response, cheers slice. Actually turns out they have a UK distributor as well so guess I can't go far wrong. Fingers crossed :)
  • 2 months later...
www.yamaha-enduros.com has scanned digital copies of 1977-1980's bike manuals.  Check it out. Most definitely worth it.
