DJYAM Posted September 1, 2015 Posted September 1, 2015 Hi,My DT 125 MX has a strange problem. The electrics, indicators, horn and brake lights only work when the bike is being revved quite high. This seems like the battery is not charged, or might be knackered.The only thing is, the headlight works whilst at tickover... It gets slightly brighter when revved but unlike the horn and other lights, doesn't die on tickover.Sound like a battery problem or a bigger fault?Thanks in advance
Moderator Cynic Posted September 1, 2015 Moderator Posted September 1, 2015 Check the battery./Main fuse./Electrolite level. Its got to be really shagged to do nothing.
DJYAM Posted September 1, 2015 Author Posted September 1, 2015 Don't have access to a voltmeter at the minute, the battery seems to produce voltage though as the lights and bits work at higher revs.The electrolyte level is between the two markers on the left hand section, full on the middle and at the low line on the right side. Is the fuse in the little white ccontainer in the positive line? Just checking that now. An update.Just looked at the fuse, upon visual inspection it seems broken.Does this explain the electrics working at high revs though? Do they not use the battery when running?
DJYAM Posted September 1, 2015 Author Posted September 1, 2015 Will go to the local car parts shop and buy a fuse tomorrow, will test it out and report back on what happens, might help solve someone else's problem, you never know.
Moderator Cynic Posted September 1, 2015 Moderator Posted September 1, 2015 The battery acts as a store of energy. The bike generates its electricity much the same as a car does. The battery fills the gaps in. When you change gear, stop start traffic riding at night. These are times when the engine cannot make sufficient electrical energy efficiently.You have to remember that bikes don't have massive charging systems as they cost horsepower. 125's don't have anything to spare. Would you give up 20% of your power for brighter indicators, and carry another 5kg of battery and the associated cosmetic implications? didn't think so.Because of that the bike relies on the battery more than a car does, without the battery the lights and such will act as you say, but! without the battery to stabilise the electrical system there will also be voltage spikes when you have that red mist moment at 10000rm and you electrical system will cop for 15v and then you blow bulbs.
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 So I put the fuse in last night, electrics working well when not running. Start her up this morning and a smell a VERY strong plastic burning smell. Under the tank on the left side, a terminal was melting plastic. The terminal has 2 red wires and 1 white going into it. The terminal is clipped onto two pipes, leading to the engine casing and the oil tank, just breather pipes. Any help much appreciated.
Moderator Airhead Posted September 3, 2015 Moderator Posted September 3, 2015 thats the rectifier, my guess is the rectifier has been passing so much current trying to re charge your flat battery that it over heated and died! I suggest a new rectifier and a new battery
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 It's just a terminal, doesn't look like a rectifier to me. Rectifier is like a black box right?Battery is charged, kicks out 6V.
Moderator Cynic Posted September 3, 2015 Moderator Posted September 3, 2015 Sounds like the rectifier to me too. Nothing else electrical under the tank.As said. Need a picture.
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 (edited) http://imgur.com/LfaT4zphttp://imgur.com/kuXUJ3QHere are two pictures. Looks as if it is connected to the tank. Have taken the tank off and it is connected to the frame. Will upload another photo. Edited September 3, 2015 by DJYAM
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 http://imgur.com/UGB3s2thttp://imgur.com/0UtrlI5Close up - Looks like a voltage recI take back what I said!
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 Thanks for all the help guys. Could this be caused by another fault or is it just the voltage rec just knackered and burned out?Cheers
Moderator Airhead Posted September 3, 2015 Moderator Posted September 3, 2015 didnt you read my previous post ? perhaps the battery is konked!
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 Yes, I did. The battery isn't 'konked' though, it's working and charged.
Moderator Airhead Posted September 3, 2015 Moderator Posted September 3, 2015 try yambits or wemoto for a replacement
DJYAM Posted September 3, 2015 Author Posted September 3, 2015 Yeah, thanks! Yambits seems like a good site. Already started polishing it! Might be too soon for that haha. Cheers
Moderator Cynic Posted September 3, 2015 Moderator Posted September 3, 2015 Thanks for all the help guys. Could this be caused by another fault or is it just the voltage rec just knackered and burned out?CheersSometimes they just die, my voltage regulator did the same at the mot a few years ago. Remember this stuff is 30 years old and 30 years ago we weren't as good at components.
DJYAM Posted September 10, 2015 Author Posted September 10, 2015 Sorry to revive this old post, Just updating. Voltage regulator swapped and working. Just bought a new bulb for the neutral light, it won't come on still. The bulb works as I put it in the indicator flasher and it works. Could this be the socket broken?Cheers
slice Posted September 10, 2015 Posted September 10, 2015 If it works out of the socket then probably yes it's the neutral light socket that's at fault, can you change it ? Or you could just rewire it externally, one wire up the side and one soldered to the bottom.
