Thunderace . Engine swap
Hi all . Got myself thunderace . Know that they are famous for using oil . Planning on doing valve stem seals in winter . Know most of the basics . Just asking how hard it is to do and do you all have any advice . Thanks for all your input
Easy with the engine out (groan) or a bit more fiddly with the lump in the frame, but that aside not rocket science as you say just read the manual first then have at it.
thanks . Just needed a bit of reassurance
I've got 2 aces, one uses oil the other doesn't! I'm lead to understand it's the rings at fault not the stem oil seals!
Apparently if you fit the rings from a GTS the problem is solved!
