September 1, 201510 yr Hi all . Got myself thunderace . Know that they are famous for using oil . Planning on doing valve stem seals in winter . Know most of the basics . Just asking how hard it is to do and do you all have any advice . Thanks for all your input
September 1, 201510 yr Easy with the engine out (groan) or a bit more fiddly with the lump in the frame, but that aside not rocket science as you say just read the manual first then have at it.
September 1, 201510 yr Author Easy with the engine out (groan) or a bit more fiddly with the lump in the frame, but that aside not rocket science as you say just read the manual first then have at it.thanks . Just needed a bit of reassurance
September 5, 201510 yr I've got 2 aces, one uses oil the other doesn't! I'm lead to understand it's the rings at fault not the stem oil seals!Apparently if you fit the rings from a GTS the problem is solved!Sent from my iPhone using Tapatalk
