hi all I've just replaced the the fork stanchion on a friends ybr 125. All was going well until the bottom Allen screw needed to be undone,  it just spun round without undoing. So the damper rod needed holding from inside needing a special tool, or in this case not, I just put two long 1/2" drive socket extensions together and the square end of one locked  the damper rod perfectly. Just wanted to get the info out there so someone else could benefit.
