Posted August 22, 20159 yr Hi. I am hoping someone can help me. I can start new topics fine, but I cannot type a message to someone, nor the admin of this site. I cannot respond to any thread either. There seems no option to type...... can anyone help?I have logged off and back on again.Thank you.
August 23, 20159 yr I have had a few problems as well with this but only on my tablet, PC is fine tablet is working now but I didn't find the problem it just comes & goes Try logging in on another device Edited August 23, 20159 yr by Tommy xs
August 23, 20159 yr Moderator I had the same trouble, there was a window at the bottom of my screen that stated 'Only Secure Content is Displayed', I Click 'show all content' and we're good to go again.
August 24, 20159 yr Admin Hi Jinx, odd one, did you get it sorted? We did just recently setup an SSL certificate which may have caused an issue.
August 24, 20159 yr Moderator Its not sorted for me Alex, I have to allow non secure content if I have anything to post, working OK on work pc thoughÂ
August 24, 20159 yr It looks like it could be the source location for the ckeditor.js files that are causing problems.the script tag shows src="//yamahaclub.com/forums/applications/core/interface/ckeditor/ckeditor/ckeditor.js"No protocol is listed, so it's likely defaulting to http:// - that'll need fixed to https:// I believe - it means that a secure site requires unsecure content to run.This is affecting all of the scripts for the CKEdiotorÂ
August 24, 20159 yr Moderator It looks like it could be the source location for the ckeditor.js files that are causing problems. the script tag shows src="//yamahaclub.com/forums/applications/core/interface/ckeditor/ckeditor/ckeditor.js" No protocol is listed, so it's likely defaulting to http:// - that'll need fixed to https:// I believe - it means that a secure site requires unsecure content to run.This is affecting all of the scripts for the CKEdiotor  that's what I thought, but you beat me to it
August 25, 20159 yr It looks like it could be the source location for the ckeditor.js files that are causing problems. the script tag shows src="//yamahaclub.com/forums/applications/core/interface/ckeditor/ckeditor/ckeditor.js" No protocol is listed, so it's likely defaulting to http:// - that'll need fixed to https:// I believe - it means that a secure site requires unsecure content to run.This is affecting all of the scripts for the CKEdiotor  Nerd!
August 25, 20159 yr What about the flux capassitor   Capt ,,,, Edited August 25, 20159 yr by blackhat250
August 25, 20159 yr Admin Thanks, this is now with IPB Support, hopefully they'll get it fixed very soon.
August 25, 20159 yr the script tag shows src="//yamahaclub.com/forums/applications/core/interface/ckeditor/ckeditor/ckeditor.js"No protocol is listed, so it's likely defaulting to http:// - that'll need fixed to https:// I believe - it means that a secure site requires unsecure content to run.The // actually makes the URL protocol relative, meaning that it will use whatever protocol you are currently using to browse the site, unlikely to be the source of the issue.
August 27, 20159 yr The // actually makes the URL protocol relative, meaning that it will use whatever protocol you are currently using to browse the site, unlikely to be the source of the issue. Ah, good to know - wasn't aware of that one  Nerd! your point? I'm a geek and proud. What about the flux capassitor   Capt ,,,, it doesn't fit on my bike. Besides, I'm a good boy, and never do 88mph *cough*
