Hi all
Have just joined so howdy!
Have an 1990 registered 350 F2 which is lovely and clean, runs well and has just over 19000 miles on.  When under load, it has a slight hesitation from about 5000 to 6000 revs.  When it clears 6000 it really flies!  Just wondering if anyone has any ideas please?  Cheers guys.
Greetings
Hi welcome to the YOC, ask your question again in the WORKSHOP section, you will get more replies there.
Hi nso.   "  sounds like the needle height ,- or needle jets need cleaning,  these are long brass tubes ,with small sparge holes on the sides,
as throttle lifts needles, a regulated amount of fuel is drawn up past the taper of needle. then when throttle is wide open , its main jet that feeds venturi ,
