Just bought a 05 R1 from a friend. Wouldnt start so got it on the cheap. Finally got the neutral light to come on but now when i try to start the bike, kickstand up clutch in all a get is a click then the insturement cluster goes blank. let off the ignition insturement cluster comes back on as if i just turned the key to on. Any help would be appreciated.
As above and bad earth, might be a faulty starter motor, check the brushes.
Magic porridge gone cold, if you had said hello in the new members area I could have kept it warm.
Edited by Cynic
If it hasn't got a crank then it definitely won't run :biggrinbounce:
thanks think i figured it out. It seems i have a short to ground through the ignition kill switch.
Seriously. Forums are at heart a collection of mates talking bikes and taking the p.
A much used comparison is a group of mates in the pub. If you asked the same question there straight out without even a hi. What would happen.
The yoc is a VERY active forum with many members and few real rules. One big sensitivity of the masses though is first post questions.
Glad you sorted it.
