Hi ajfter a a little help ,I am fairly sure that my flasher unit is crackered.. So will an normal three pin unit be ok to replace it with..Roy
As long as the present one has 3 pins it should work, only real way to find out is fit it ! Just make sure it has the same rating on the side, you know voltage and amp draw.
Ah yes forgot that bit, BUGGER!! :shrug:
