August 7, 201510 yr hi recently become a proud owner of a tzr 125 1990 has a 2rh motor and a newer chassis but not the 4dl .I've ridden others before and one had the powervalve pinned .mine is not running but will be soon .haven't tested the servo yet but was once told that it is possible to link the valve straight to the throttle. just wanted to verify?
August 7, 201510 yr Moderator I have moved you to the workshop.Say high in the new members area, otherwise you come across as one of the many one post wonders which we get an awful lot of, one question then never seen again.
