Posted August 2, 201510 yr Hi dos eny one no what to do when ur kick start shaft keeps klicking when bike is runing ?
August 3, 201510 yr Normally means the shaft ain't sat in the right position when disengaged could mean a week spring or some minor adjustmeet to get it back into its proper stopping position
August 3, 201510 yr Moderator Yep. Needs the sidecover off to check. Soon too! debris could contaminate the gearbox causing it to jam if extreem.
August 3, 201510 yr Yes as above really, best to check that the return spring has not fallen out of the retainer hole, it might even have broken the spring so best done sharpish.
