August 1, 201510 yr this is my restored 1988 dt125r field bike. obviously this is not me in control of it its my brother lol im just the mechanic
August 3, 201510 yr Got any better pics of the bike looks good from what I can see in the picture. Have you gone completely stock running wise ?
August 3, 201510 yr Author for some reason i cant get any more photos on. But the engine is completely stock it has just been fiddled with like where the air/fuel mix comes into the barrel the two little 'fingers' if you like have been completely rounded off using a file so it flows through better and that made a noticeable difference, i have also messed with the carb a bit to give better performance other then that it has a dep exhaust system. As for cosmetics i had the frame powder coated and the front forks painted white as well as the triple clamp which i think looks much better. i tried to keep it as original as possible but with a few tweeks of my own. it is actually for sale on gumtree listing :1124412462 where there are better pics too
August 3, 201510 yr Sounds good mate love a good dt project mines gone far over stock but still a dt at Hart lol
August 3, 201510 yr Author i like to keep things original that way they are worth more in the future but thats just me
October 25, 201510 yr Hi I have a 2002 Dt 125 R, 6500 miles on clock and would love to know the Carb settings you used, mine is a standard engine with reed switch taken out of speedo I have had bike 3 months and fitted a new Mikuni TM 28 ss Carb and fitted a 220 Jet but The bike hates idling, hates acelerating unless its at 6000 rpm, and at low revs bogs alot also bowl overflows when it is ticking over any clues, tips or info on setting the Carb up would be really appreciated, Oh and how high is that Box the bike is on I need to make one of those lol.Thanks Edited October 25, 201510 yr by Leftyno1
October 30, 201510 yr REALLY sounds like the float height setting being incorrect that mate might just need a good clean or be sticking a bit give it a good clean and check the float height Edited October 30, 201510 yr by Benjamin15
October 31, 201510 yr If your running a standard exhaust you want to be on a 210 main jet bigone exhaust is 220 main and dep is 240 and as above floats will need adjusting to stop over flowing Edited November 3, 201510 yr by Chalkey46 Pictures
November 16, 201510 yr Great shot with your brother in the track. It also gave me some plans in creating a supermoto project. I envy you guys.
