nice job lall I got all my rubber mounts from fowlers cost me about £10 for six with the postage
  • Replies 64
  • Views 12.8k
  • the front mudguard that I use for testing is almost done need wet sanding and apply clear. the result is acceptable. in the pics don`t look so good but its ok I hope I will get the clear tomorr
  • Nice find Lassy, as Drewpy says just run it for the summer, the only real problem that I had with mine was the lower frame rails rotting out where they bolt to the engine through a rubber mounting, pa
  • Ttaskmaster
    Ttaskmaster
    The H-shaped thing is officially a "Cam Cover Gasket", although may also be called a "Rocker Cover Gasket". FJOC does them for £23. You will need the joining fee, but it's worth it if : You expect to
damn, and I buy 4 with 12+5 pounds from yamabit :)) ... but I guess are different stuffs.
Mine were Yamaha parts
the thing with Yamaha parts and all the big makes, they utilise a lot of older parts, just change the codes around.
I buy stuff just by visualization and hope they fit ( mostly right)
after I buy those o-rings, I found 8 from my old panniers that I have on the xvs. same dimensions. :banghead:
I want paint some "FJ" and "FJ1200" on the fairings but I don`t know what color to use. any idea?
