June 20, 201510 yr Hi guys just brought a dt125r 1989, for some reason the old owner put a 2005 loom on it and could not get a spark, could anyone give me a simple diagram to follow to enable it to run ? Thanks Ben
June 21, 201510 yr Moderator I would recommend saying high in the new members area. So you haven't got a manual for it then?
July 11, 201510 yr Not sure what "a 2005 loom" refers to?If no spark...Check key switch and kill switch, especially if corrodedCheck the plug wire follow it to coil, everything look right?Remove the gear shift leverPull the flywheel cover.Inspect the flywheel, corrosion remove with emery clothcheck for spark after cleaning.still nothing, pull flywheel and inspect /replace stator plate.
