Been trying to undo the screws that hold the sidestand kill switch onto the frame, the screws will not turn at all, like they are superglued , was wondering if there are some kind of tabs that need to be lifted up , so i can get this switch of, as i have a no spark prob myself, Was fine the day b4, then just would not start, Have to wait till Mon, and talk to a mechanic who owns the bike shop, and def no,s what hes talking about, , Heard about bypassing the switch, which is what i might do, but i need to no if its the switch causing the spark prob, had the bike three and half yrs, and never had this b4, Only found out about this kill switch after messing with carb, taking tank of, wiring, seat aswell, Had 2 punctures to fix aswell, A 5 min job had turned into abit of a nightmare, Started out with one of the cables to the battery snapped, Willhave to wait till tWed b4 i can check it out as i might be out of town 4 a couple days
Just back track through the loom till you find the connectors, then either disconnect or bypass as required.
Not like its needed for the mot.
