Dt 175c spares
is there a source in the uk for spares, I need front and rear mudguard and rear silencer, plenty in the us but I think when you add post and tax it will be expensive
cheers
Aye vin" they do come up now and again, the rarest part is the small triangular gusset [ mounts numberplate bracket ]
The fsie numberplate bracket is the same, thers repro on ebay, the fronts are on yuni-parts [ ebay] the stays are different on dt"s
19 inch & 21 inch front wheels , the muffler is same as DT125 twinshock, not the DT100 tho..
thanks for the info, not keen on the rear light (which Is missing on mine) so gonna put the small one with built in number plate that I use to fit years ago if there still available
Only other changes I plan are longer rear shocks and if I can the front fork extenders just to give it a bit of a taller look.
