June 12, 201510 yr hi.. i have a yam dt125x supermoto. 2006.. the powerband has stopped working.. ive checked the valve, and it has not siezed and it is free, so the motorised unit has stopped the opening and closing of the valve. would any of you bikers know how to check the motor... i mean is it on a fuse or a relay.. or is it just duff then.. .... please tom...............
June 13, 201510 yr Hmm " When you switch on ignition, does it whirrrrrr, [ thru cleaning cycle,,] ? Do an intro , in new members, ALSO
June 16, 201510 yr Moderator everything you always wanted to know about powerbands http://www.planetash.net/gos/powerbands.html
June 17, 201510 yr Typical one hit wonder " posted 6am - looks back in @ 8am, nae answer , so hes off
June 18, 201510 yr Moderator Ha Ha Haaaaa!!! , I'll be ordering two , 'cos my Elsie's a twin ! you get two power bands in a packet
June 19, 201510 yr you get two power bands in a packet Feck !! That's good value . If you put two sets on I'd say you'd have to bungee yourself onto the saddle .
June 19, 201510 yr Moderator you get two power bands in a packet That shows the quality of proper tuning. That initial surge then on to the full power twin band hit at 6k. Need to check your licence though. Prob above A2.
June 19, 201510 yr If the bikes been rebored will I need 1 and a half bands? If I cut the second band slimmer will that be OK?
June 19, 201510 yr If the bikes been rebored will I need 1 and a half bands? If I cut the second band slimmer will that be OK? Only on Monday's
June 19, 201510 yr Moderator If the bikes been rebored will I need 1 and a half bands? If I cut the second band slimmer will that be OK? you normally have to measure the width of the bands to the cc of the bore, that way the power band is resonating at the correct frequency of the engine and ensures longevity as well as power! hope that helps
August 5, 201510 yr Wow , "Powerband in EVERY gear " . - http://www.gumtree.ie/a-motorbikes-scooters/meath/2003-kawasaki-kx/1001327307600910430471209
