hi my name is byron i live in wrexham north wales.
i have never been on a site like this before as i usualy stick to porn sites .i hope you can excuse my poor spelling and punctuation as its never been a strong point of mine.just bought recently a 1996 yamaha thunderace previous to that a fzr1000 exup and a 2001 r1 streetfighter which got pinched \WANKERS/
having trouble with thunderace cant get fuel pump to run ,if i pour petrol down carbs starts instantly and so i have replaced wiring loom as it was in a mess
fuel pump as i thought this might be faulty but still nothing ,i connected pump to battery terminals and did not pump so might need another but still does not explain no voltage in wires to pump when i put tester on them
could do with some help please
I'll save slice the text time.
General form is to introduce yourself in the new members area, the amount of 1 post questions that come would surprise you and it makes people unlikely to reply. An introduction goes a long way to help that, as does with due respect, punctuation.
Say hi and give your post a quick edit to show your issue more clearly and you will get plenty of help.
+^ please introduce yourself.
Easiest workaround is to find a +12v that comes on with ignition, and then use that as a signal for a relay to run the fuel pump.
Thank you Cynic !!! :biglaugha:
