2010 XJ6 F.
Hi, the front right indicator is not working. The rear right indicator works. The bulbs are all ok.The green light light in the headlamp flashes faster than normal when turning right. Left indicator works fine front and rear.
Any ideas will be much appreciated.
Have a great Bank holiday.
Bad connection, most likely earth. Get the multimeter out and start checking for continuity.
Bulbs are all ok.
If i had a quid....?
Please say you have swapped the bulb with a known good one from one of the other indicators.
