May 20, 201510 yr Hi Everyone, The radiator fan on my 2011 XJ6 blew a fuse on the way into work the other morning, I swapped out the fuse and now the fan when it does kick in goes very slow and isn't enough to cool the engine. I have looked on ebay for a replacement fan and can't seem to find any. Does anyone know if there is an equivalent that is easier to source. Cheers, Steven
May 20, 201510 yr Why not just oil/lube the fan? If you can get it off then it is usually just muck and crap that causes it to run slow, sometimes it's the brushes worn out but most often it's just neglect in keeping it clean. Most folks think it is enough to just wash the bike but some things need a more intimate approach.
