78 dt 175 end no we're in sight
Your charging circuit is the white wire. The brown feeds the cdi, if its a bad coil your cdi wont be getting enough voltage to actually work.
  • Replies 81
  • Views 12.9k
  • sounds choked up and lots of smoke...I wonder if the crankcase has lots of oil in it ?
  • The 12v bikes have a different stator. Easier to ask if its electric start.
  • What you should have on a 175E, 1, 4 pin plug with yellow, white and light blue. (the white is green and white between the plug and the stator. 4 separate wires, red, brown, white and red trac
https://youtu.be/rwfpROC6-p8
It was the coil(brown wire) I took the one off the stator that was originally on the bike and put it on the one I just bought and it makes fantastic spark. Just gotta tune everything up
